Don’t get that card. Those are terrible value. I suggest the amd rx 6600 for a value pick. Or for a little more look at the rx 6600 xt or 6650xt. Those last 2 cards are pretty close in performance, whichever one you can get the better deal on is the one to get there.
These amd cards though are closer in performance to an rtx 3060, but typically cost less than the rtx 3050 which is why I don’t recommend the 3050.
What’s are the specs of your system including cpu, motherboard and particularly make and model of your power supply?
