F frenzy1 Reputable Jul 31, 2014 2 0 4,510 Jul 31, 2014 #1 Hey, i am going to upgrade my old gtx 570 to 780, and by pc has a 600w power supply, im wondering if i am going to buy the 700-750w. The question being, do i really need 700^? Or can i spare a few bucks by keeping the 600w one?
Solution CGurrell Jul 31, 2014 This EVGA PSU will work fine too http://pcpartpicker.com/part/evga-power-supply-120g10650xr Basically, you're much better off with a high quality 650W PSU than cheaping out on a low quality 750w PSU. And yes, both the EVGA and Seasonic PSUs are of extremely high quality and should both work fine
S Suztera Polypheme Mar 18, 2014 12,730 0 60,960 Jul 31, 2014 #2 Depends on what quality the power supply you are getting. A Seasonic 650W will be fine. Upvote 0 Downvote
CGurrell Honorable Feb 3, 2014 1,098 0 11,460 Jul 31, 2014 Solution #3 This EVGA PSU will work fine too http://pcpartpicker.com/part/evga-power-supply-120g10650xr Basically, you're much better off with a high quality 650W PSU than cheaping out on a low quality 750w PSU. And yes, both the EVGA and Seasonic PSUs are of extremely high quality and should both work fine Upvote 0 Downvote Solution
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Jul 31, 2014 #4 A GeForce GTX 780 needs 42 amps on the 12v rail and a 600 watt power supply. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Jul 31, 2014 #5 That EVGA power supply isn't a good one the B2 , or G2 series is the good one. Upvote 0 Downvote
CGurrell Honorable Feb 3, 2014 1,098 0 11,460 Jul 31, 2014 #6 That EVGA power supply isn't a good one the B2 , or G2 series is the good one. My bad! Go for the seasonic G-series or EVGA G2/B2 as SR-71 said Upvote 0 Downvote
F frenzy1 Reputable Jul 31, 2014 2 0 4,510 Aug 1, 2014 #7 Thanks for the informastion guys, appriciate it Upvote 0 Downvote
