What Power Supply Do I Need?
gogleos
5
I'm a first time pc builder and I don't know how much power I need. 600w, 750w?
My parts list:
ASUS black 24x dvd burner
Seagate Barracuda 1tb 7200rpm 64mb cache SATA 6 Gb/s
EVGA superclocked w/ ACX cooling Geforce GTX 770 2gb
Logitech mouse and some kind of keyboard
2 x 4gb G.SKILL ripjaws x series ram DDR3 1600
MSI z87-g45 gaming LGA 1150
Intel core i5-4570 Haswell 3.2ghz LGA 1150 84W Quad-core
2x Cooler Master sleeve bearing 140mm fan
Corsair carbide series 300r w/ 1 140mm fan and 1 120mm fan included
If you have any other comments on my build, this would be much appreciated.
You can check at: http://extreme.outervision.com/psucalculatorlite.jsp. But if you look on the (box?) info from EVGA it says 600W/42A on the 12V line or greater. So 600W is fine for what you've got. But maybe 850W if you eventually want to run 2 770's in SLI.
I doubt I'll ever go SLI on this, I'm stretching the budget as it is.
pcpartpicker says that it'll need 421 watts, but I used a psu calculator I saw somebody post and it said like 530 or so. And the specs of the video card says it needs a 600 watt minimum
I'm still looking for the post to read, guess I'm still getting to grips navigating the forum, but I was told that "Tom's benchmark team built i5 OC + GTX 760 with 450W 80+ gold last month"
Maybe someone can post a link.
