[SOLVED] What Power Supply should I get?
Apr 22, 2020
9
I'm pretty new to PC building, and the whole PSU system is confusing to me. I would be great to see what wattage PSU I would need, and about any reputable brands/models.
CPU: AMD Ryzen 3 3200G
Mobo: ASRock B450M-HDV R4.0
RAM: G.SKILL Ripjaws V series (1 x 8)
SSHD: Firecuda 1TB 7200 RPM
Any feedback on the PSU or build would be greatly appreciated.
Are you using a GPU? Or the IGP in the 3200G?
If just using the IGP in the 3200G any quality lower wattage PSU will work. You won't go over 200W. You probably won't go over 150W. So any quality 300-350W will do. You might want to get a bigger 450W for when you add a GPU.
