So I am working on a custom wooden case mod, is pretty much a rectangle box. I am planning to watercool this rig and I need help on the airflow design:
I want to use UV green fans and currently own 3 of these:
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_221&products_id=24962
Specs about my case/build:
i5 2500k
Radeon HD 7950
ADATA 16gb RAM
A few HDD's
650watt PSU modular
I own this pump: http://www.dangerden.com/store/dd-cpx1-12v_pump.html
Case:
7x7x38 (inches)
Front window (long side of rectangle) plexi
Material: MDF Wood
I dont intend on OCing like crazy, only slightly.
My question is what kind of radiator do I need for my setup? I want to use 2x120 (fits best), but will that run too hot (was planning single loop)? Only the GPU and CPU will be watercooled
What thickness of tubes should I use?
How does my airflow look in the case? I originally wanted to use a 2x120mm to push air out of case via radiator, and have 1 fan to push air INTO case.
![vkaw3.png](/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fvkaw3.png&hash=008b1f2e34d0edb3224d66c58314537b)
i5 2500k
Radeon HD 7950
ADATA 16gb RAM
A few HDD's
650watt PSU modular
Case:
7x7x38 (inches)
Material: MDF Wood
