[SOLVED] What ram speed and timings is best?
Mar 3, 2020
Hello.
I got:
Z370-A Asus Motherboard.
i7-8700k.
1080 Asus Strix.
16 GB Ram corsair 3200 mhz
(no rbg - wanna upgrade)
550w Corsair PSU.
i make music in FL Studio and it can get heavy load and game and sometimes stream.
I have 3 monitors connected.
What ram should i go after?
3200 Mhz Corsair RBG PRO C16 - (CMW32GX4M2C3200C16W)
or
3600 Mhz Corsair RBG PRO C18 - (CMW32GX4M2D3600C18)
- Help me plz! 😀
Hello.
I got:
i7-8700k.
1080 Asus Strix.
550w Corsair PSU.
or
- Help me plz! 😀
Really, 3000mhz is good. Your Mobo also reaches high ram timings. It really depends on the price. I found 3200mhz 16gb ram for the same price as 3000mhz 16gb ram therefore more worth it getting the 3200mhz in this situation. So it depends on the price difference. You won't really see a difference in gaming but a slight difference...
Hello.
I got:
i7-8700k.
1080 Asus Strix.
550w Corsair PSU.
or
- Help me plz! 😀
Really, 3000mhz is good. Your Mobo also reaches high ram timings. It really depends on the price. I found 3200mhz 16gb ram for the same price as 3000mhz 16gb ram therefore more worth it getting the 3200mhz in this situation. So it depends on the price difference. You won't really see a difference in gaming but a slight difference in editing. I would not recommend getting it if the price is around £30 more ($38)
Thanks for fast reply!
The price difference is 30$ USD between 3200 mhz C16 and 3600 C18, i forgot to add it to the thread.
i have 3200 mhz NON-RBG, but i wanna upgrade the price difference between non-RBG and RBG is minimal where i live, just not sure its worth the money buying 3600 mhz C18.
And i heard C18 timings is worse than C16? that is what confuses me a bit..
If 3200mhz is cheaper, get whats cheaper. There is no difference after all anyways within the latency and clock speeds. So in conclusion I recommend the 3200mhz kit
Reactions: Collapz
