[SOLVED] What RPM Speed is recommended for my Pump Fan?
Dec 17, 2020
20
I've just finished my new PC build, and it's my 1st time using Water cooling aswell.
I'm using a
CoolerMaster MASTERLIQUID ML240L V2 RGB to cool my Intel Core i9-10850K CPU, and I am wondering what RPM speed is recommended for the Pump Fan. At default it was at around 750RPM, then I went to 2400RPM and im not sure if its too high or its ok if the pump will work 24\7 on 2400rpm.
the fans on the radiator work on around 1050RPM
my cpu temp on idle mode about 31c
Thanks.
Make and model of your motherboard? As stated on the manual for the AIO, the pump header either can go onto a chassis fan header or an OPT_CPU fan header. Either which way, you're good leaving the fan header on full speed. You could tinker with the pump speed a little but for your platform, I'd say leave it as is.
My Case corsair 460x.
My mobo asus rog strix z490 gaming-G
I connect the aio to W_Pump+
