My stock approach to this perennial question:
Some games are graphics limited like fast action shooters.
Others are cpu core speed limited like strategy, sims, and mmo.
Multiplayer tends to like many threads.
You need to find out which.
To help clarify your CPU/GPU options, run these two tests:
a) Run YOUR games, but lower your resolution and eye candy.
This makes the graphics card loaf a bit.
If your FPS increases, it indicates that your cpu is strong enough to drive a better graphics configuration.
If your FPS stays the same, you are likely more cpu limited.
b) Limit your cpu, either by reducing the OC, or, in windows power management, limit the maximum cpu% to something like 70%.
Go to control panel/power options/change plan settings/change advanced power settings/processor power management/maximum processor state/
This will simulate what a lack of cpu power will do.
Conversely what a 30% improvement in core speed might do.
You should also experiment with removing one or more cores/threads. You can do this in the windows msconfig boot advanced options option.
You will need to reboot for the change to take effect. Set the number of threads to less than you have.
This will tell you how sensitive your games are to the benefits of many threads.
If you see little difference, your game does not need all the threads you have.
It is possible that both tests are positive, indicating that you have a well balanced system,
and both cpu and gpu need to be upgraded to get better gaming FPS.
You have a crazy amount of ram.
Is there a reason for 64gb?
With a $400 budget for a cpu upgrade,
I think you can find a 12th gen i3-12400 processor for $210 and a B660 DDR4 motherboard for $150.
Here is a review of the 12400:
https://www.tomshardware.com/news/intel-core-i5-12400-review
If you need a graphics card upgrade, good luck and patience.
Prices are getting better, and intel may well shake up the market soon.
A significant upgrade of the 1060 would be to at least a RTX3050 class card.
That might fit your budget.
Anything stronger, and you may also be looking at a psu upgrade.
