What size power supply do i need to run a 2000w car amp
Just buy a decent Hifi - dont forget that a 2000 watt amp is probably rated for about a quarter of that ie 500w. It probably will put out 2000 watts for a few seconds before it blows/ overheats / drains all the street lights :pt1cable: :pt1cable: by the time you have four / 5 speakers running off it it is putting out about 80-100 watts per channel which is what a good surround sound reciever will give.
Before you buy anything check your home fuses/breakers, figure 1amp = 125 watts, a typical fuse/breaker for any room except utility/kitchen, should be 15Amps, which would give you 1875Watts, normally you don't want to exceed 80% of the fuses capability. For this case, 1500 watts would be your max on a 15A fuse/breaker.
Amps x Volts = Watts
In Summary:
15A: 1500Watts
20A: 2000Watts
25A: 2500Watts
30A: 3000Watts
Remember this is EVERYTHING on that fuse/breaker, which is normally two rooms per fuse/breaker, so if you max out on one electrical socket (which I don't recommend anything over 1300watts on an individual plug), nothing else can be using electricity or you'll blow the fuse.
Too many Amps on a fuse/breaker can cause significant damage to your homes electrical system, depending on how old your home is, wire guage etc...
Hope this information helps.
Also, keep in mind that a lot of car stereo shops will oversell wattage on cars... based on A x V = W, as stated above, a 2000watt Amp would require a 165A Alternator in a car. Alternators of this size are typically found on large diesel trucks, whereas 120A's on Pickups, and typically 60-80A on cars (stock). Cars/Trucks usually are 12Volts, to mimimalize the compexity of vehichle electrical systems.
You would probably be fine pushing a 1000watt PSU into the Amp, however check the 12V rails for maximum wattage, even if you got 700Watts, that would be about the maximum you could get from a car alternator if you never upgraded it. (Meaning little to no change from what was in your car, assuming no upgrades).
Also on fuses/breakers, typical homes with 15Amps have 14 guage wiring, and 20Amps 12 guage, do not exceed the maximum specification of Amps on the wire or you'll probably start a fire. Scratch that: You will start a fire if you exceed the amps/volts on a what a wire is specified at.
1000watt psu from a old server will work just fine, mine produces 40 amps
no sweat of totally clean power with no hum or noise i can hear. That likely wont totally max your amp, but its unlikely your amp actually put outs more than 400rms.
Yes, you can. With a 2000w DJ amplifier. There out there, just look for one with the lowest harmonic distortion. The 2nd best option, rig up a high output alternator to run off a beefy electric motor. If you're deadset on car equipment indoors look up BigDWiz on YouTube. He shows a pretty beefy indoor setup.
https://youtu.be/vfIrmsA3C1A
Look at 3:08 for an idea of the power needed to run 10,000w indoors. For 2000w you will need at least a HO alternator, a battery or two, and a beefy cap (5-25 Farad). Go with a DJ amplifier unless you ABSOLUTELY have to!
Reactions: Rogerm 90
