What type of card and power supply I need
biggreddone
5
Hello everyone,
I am new to asking for help on forums especially when it comes to my computer. I am a tech guy, but I am mostly proficient in software not hardware. I know enough about hardware to be very distructive. I recently found out my video card will not cut the mustard with a few of my games so I went on the hunt to find another card. There are several options but I don't know what would be the best considering I am on a budget of $200 or less and on top of it need a new power supply since mind is only 300 W. Would someone please help me out with recommendations I would greatly appreciate it?
Thanks
Below you will find my computer specs:
Base processor
Phenom-9650 (A) 2.3 GHz (95W)
2000 MHz HyperTransport 1.0
Socket AM2+
Chipset
GeForce 6150SE nForce 430
Motherboard
Manufacturer: Asus
Motherboard Name: M2N68-LA
HP/Compaq motherboard name: Narra3-GL8E
Power supply
300W
Memory
Component Attributes
Memory Installed 7 GB
Maximum allowed 8 GB (4 x 2 GB) (64-bit OS)
Hard drive
640 GB SATA 3G (3.0 Gb/sec)
16X DVD(+/-)R/RW 12X RAM (+/-)R DL LightScribe SATA drive
Expansion slots
PCI --- One (One available)
PCI Express x16 --- One (One available)
PCI Express x1 --- Two (One available)
What resolution is the monitor you are running right now? According to HP your PC came with a 9800 GT which is probably getting bottle necked by your CPU. Depending on your resolution a CPU/Motherboard upgrade may be your better option.
Well what video card do you have now? lol
Anything decent will be bottleneck by your processor because of its slow clock speed.
I have GeForce 6150SE nForce 430 for a video card right now. Does this help?
Here is my current card: GeForce 6150SE nForce 430
My current resolution is 1440 x 900 at 75 Hertz refresh rate.
What you think?
My suggestion for about $200 would be...
PSU -
OCZ ModXStream Pro OCZ500MXSP 500W Modular 86% efficiency power
$69.99
($49.99 after $20.00 Mail-In
Rebate 17-341-016 )
Free Shipping*
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016
Graphics card -
XFX HD-485X-ZDFC Radeon HD 4850 1GB http://www.newegg.com/Product/Product.aspx?Item=N82E16814150351
or even the 512MB would do...
SAPPHIRE 100245L Radeon HD 4850
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102770
But check if you get a good deal with 4870 512MB...If you get it for less than $130, then go for that one...
