What would be the best upgrades for my low level pc?
WasiGamer
48
Specs:
CPU: i5 2300 @ 2.8 GHZ
GPU: EVGA GTX 1050 2GB SC
RAM: 8GB (1333 MHz DDR3 Non-ECC) , Motherboard only has 2 DIMM slots btw, dual channel I believe.
Storage: 500 GB (5200 rpm I believe) Mechanical HDD
So, best upgrades whilst not breaking the bank? Don't want to swap out the case or Motherboard.
The PC is actually a OEM pc (I believe, a lot of "I believe"). It's a Dell Vostro 260, 300W PC. I'll attach a pdf file containing all specs (skip to page 44/65).
As the PC is an OEM, there's no molex cable to attach anything more powerful than a 1050. So that's a mini problem, but I could get a molex adaptor? I'm not sure, I used to be interested in basic PC shenanigans hence I kinda know this sh** more than the average PC user.
One more thing, I bought the PC on eBay in October 2016 mainly for my studies, REFURBISHED.
I'll most likely respond quickly, unless I'm asleep midday and before 3PM.
Any suggestions would be greatly appreciated! Thank you.
My PC specs and available functions (Excluding the GPU I inserted a year ago): https://www.mrmemory.co.uk/downloads/memory-configurations/69814.pdf
Edit: Just realised.... AN SSD? IS it really worth it? You hear PC nerds saying "It's impossible to have a modern pc and not include an SSD".But I'm not a handsy guy. I'm no good with making stuff. I find it hard to assemble an office chair or desk, so I'd prefer to avoid that stuff if possible.
WasiGamer
48
There are only 2 DIMM slots though...
bnewlands32
Commendable
Jan 5, 2017
190
I was thinking you had 1 stick of 8 gb. do you have 2 sticks of 4?
A swap out to an SSD would net you the most visible quality of life improvements. Especially since you may have just a 5200rpm, most of the slow downs hand holds ups you experience on that machine are likely coming from the HDD.
It's very easy to do, just two cables.
nobspls
Notable
Mar 14, 2018
892
9
1,165
An i5-2300 and GTX1050 is not bad at all. It is quite serviceable for most tasks and as long as you are not demanding highest quality gaming at highest resolution it will be plenty good for games too.
WasiGamer
48
Yes, 2 x 4 GB
WasiGamer
48
Ok, would you say it's worth going for a 120GB rather than a 60GB cos I don't wanna go all out. Surely, If I put Windows on the SSD and maybe a couple of applications, that'll be good enough.
Secondly, any good SSD's (60GB and 120GB), off the top of your head. The popular one by Kingston is a good deal, 500 MB/s write and 450 read.
