Whats the Best way to connect Sororund system
Jhonee310
9
Hello,
i wouls like some help on figuring out how to connect my sorround system 5.1 to my tv lg lcd lk450 its an old one its a techniqs sag-90im currently using a 3.5 mm to rca to connect from the receiver to the headphones jack to the tv is that a good idea i did that since i had the cable and i tought it would work great but sound isnt that great sound only comes from the center speaker since im using 5.1 i would like to hear from all speakers o r is it normal for the sound to only come from the center speaker welll hopelly someone can help if you need more info please ask
If you are using RCA then the sound should be coming from the left/right channels and no sound should be coming from the center.
Either your receiver settings are off or you connected the wires to the wrong channel.
alright well the thing is that in surround sound mode it does come from all speakers
the problem is that the sound coming from the middle speaker is the loudest
you can barely hear the front left and right or the back left and right
is that normal the center speaker simply over shadows all other speakers
so all i could hear is voice coming from the middle speaker and cant really listen to effects etc. etc.
is that the way its to behave???
well yeah and in stereo mode its backwards lol
i can hear all four speakers well they sound great
but the thing is that i can barely listen to voice
the center speaker doesnt give out any signal
and im using a rca to 3.5 mm
to connect my sorround system to my tv
