Did you go into the system settings and set it to 75 Hz?When I use my Desktop PC it reads at 75hz. So yes it is a 75hz Monitor
HDMI supports 75 Hz just fine.Make sure the cable is not a standard HDMI which typically are only able to produce 60hz, if not right click on home screen go to display, settings and go to advanced and change to highest setting
