[SOLVED] When PC is powered on GPU starts up for a second and then stops.
lucamakar21
18
I recently built a new pc but upon completion only the GPU seemed to get power as it was the only component to light up. The motherboard led will not turn on. All power cables are plugged into the motherboard except for the cpu pwr 2. When I press the power button the gpu starts up for approx. 1 sec then immediately turns off. I am wondering if one of my components is shot, or maybe I installed something incorrectly.
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($264.89 @ Mike's Computer Shop)
Motherboard: MSI MPG X570 GAMING EDGE WIFI ATX AM4 Motherboard ($289.99 @ Amazon Canada)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory ($124.99 @ Canada Computers)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($119.99 @ Canada Computers)
Video Card: Asus GeForce RTX 2070 8 GB STRIX GAMING OC Video Card ($609.00 @ Canada Computers)
Case: Corsair SPEC-06 ATX Mid Tower Case ($128.99 @ PC-Canada)
Power Supply: Gigabyte 750 W 80+ Gold Certified Semi-modular ATX Power Supply ($99.99 @ Canada Computers)
helper800
I was not aware gigabyte even branded some PSU's which means they are probably low quality. I would immediately suspect the PSU. Look into getting a Seasonic, Corsair, or EVGA branded PSU.
helper800
