Question When system starts using paged memory?
Dean0919
305
41
18,740
Please someone explain me in a simple way, when Windows starts using paged memory (when physical memory isn't enough and it uses SSD/HDD instead)? How to know when this happens? For example, if I open Task Manager, if in "Commited" number exceeds my physical memory (32GB), does this mean, now system is using my SSD/HDD?
I want to have enough RAM so system doesn't use my SSD, so SSD doesn't wear off sooner and it lasts longer. Right now, in my screenshot it says 23.0/42.4GB for committed and 17.GB in use. As I understand it's not using right now my SSD, right? But few days ago, I noticed that my memory usage was 80% and in committed it said 50GB/42.4GB, if I remember correctly. Does it mean, in that scenario OS was using SSD because physical RAM wasn't enough?
P.S. Shall I keep page filing on my SSD or change it to HDD? And shall I upgrade to 64GB if sometimes I reach to 80% memory usage?
The first indication is that your performance with get terrible.
The screen shot you show has 14GB of available RAM out of 32GB installed.
Windows manages ram.
It will keep unused pages in ram in anticipation of instant reuse.
You will almost always see ram use from task manager in the 80% area.
That is not a problem.
The real problem comes when a needed virtual page is not resident in ram and needs to be fetched from the page file.
When running actively, open task manager then resource monitor.
Look at the memory tab and find the column for hard page faults.
If you see a continuous hard fault rate of more than zero, you likely need more ram.
When you get a hard fault, the cpu stops dead for that app while the page fault is resolved.
You want the page file on a ssd, not a HDD. A page fault is resolved some 40x faster on a ssd.
With ssd devices now in the TB range, wear is no longer a realistic issue to be concerned about.
Reactions: Dean0919
So, if I understand correctly, if committed number exceeds number of my physical memory, then this means system is using additionally page file thing (SSD/HDD) and this means I need to upgrade RAM. Correct?
It means you need to take a look at WHY you are using so much RAM. Do you have a bunch of things running at start-up that you never use? Are you trying to run Chrome with 1000 tabs? Are you trying to game and do 4K video editing at the same time? IMO, none of those things are a reason to upgrade RAM. You could, and that would hide the reason for running out.
Windows use several hidden files for caching all the time and that can't be influenced no matter how much physical RAM you have. Only adjustable one is paging file but none of them will have any effect on SSD/HDD "life" as it's been used much more by other services, paging file influence is very, very small.
That said, only way to have more RAM is to add more RAM or to optimize your system to use as little RAM as possible in idle state.
If you are so (unnecessarily) concerned about SSD life, you can always set page file to some minimal value or to 0 but some programs demand access to page file or even certain size, Adobe for instance is notorious for that.
Yes, I do heavy multitask. This is my usual taskbar:
As you see I usually have 20 Chrome profiles opened all the time (I need it for some certain game) and as you see I have opened bunch of other apps and plus when I decide to play a game, I don't close those things, so imagine all these apps + heavy gaming. Sometimes it does exceed 32GB. I have two sticks of Patriot Viper memory and I still have 2 more empty slots on motherboard. I'm thinking to get another pair of those memory sticks...
Bought Patriot Steel Viper series, 2 sticks of 32GB and even my current 2 sticks of 16GB Patriot Vipers worked fine along with these new ones, so in total I have now 96GB of RAM. Don't think I will ever make them full, so I'm definitely safe from such scenario now. By the way, I bought those new sticks for $88 from a local guy.
More ram is never a negative(except cost)
Have you checked your hard fault rate?
If you have no hard faults, adding ram is a waste.
For further investigation, OP can fire up the oldie but goodie - perfmon.
It has an 'Average page faults/sec' counter. Note that some programs (and Windows itself) will write/read to/from the page file, regardless of how much system RAM you have available. This behavior cannot be changed.
OP may also want to take a look at optimizing his system/startup tasks. An optimized Windows 10/11 with little to nothing starting up automatically, should settle to only using 3-5GBs of RAM after 3 minutes at the desktop.
Reactions: Dean0919
Yes, I always have configured what programs are on startup, so no unnecessary program goes there. Only 9 programs startup:
  1. Lightshot
  2. Razer Synapse
  3. Plex Media Server
  4. Qbitorrent
  5. Steam
  6. Lingoes64
  7. Google Drive
  8. RtkAudService64 (audio driver)
  9. SecurityHealthSystray (Windows security as I understand)
But like I said, I use 20 Chrome profiles opened all the time, MusicBee, OneNote, Messenger app, Whatsapp app, HWinfo64, Powertoys, Nvidia control panel, Playbuddy and currently 14.8GB RAM in use and if I launch some heavy game like BF2042 then my maximum RAM usage goes up to 26GB (depends on game).
