if your current power supply does not supply the necessary PCIe power cables than you will need to purchase a new one.if anyone knew if a hp z230 psu can 2 8pin connectors?
Is there any connectors or adapters i could buy? If I change power supply I need a new case, I may as well build a new system at that point.if your current power supply does not supply the necessary PCIe power cables than you will need to purchase a new one.
if this is a prebuilt HP system than you will not be able to replace the power supply with a standard retail model.
HP uses proprietary models designed to fit their small-form factor cases and they do not provide proper replacement models.
you will need a new case, new power supply, & new motherboard to set this up.
No. Adapters are not safe. You'll need a new system since the one you have is not made to be upgraded.Is there any connectors or adapters i could buy? If I change power supply I need a new case, I may as well build a new system at that point.
