Question Where can i get replacement battery for Asus Rog GV551VW in India ?
Jul 4, 2023
I tried Asus support, looked for 3 years but no luck, Asus support always says "out of stock" and service center says get help from support. Had real bad experience with Asus support. Never buy an Asus laptop.
If it's the CMOS battery, ALL motherboards use the very common CR2032 button cell. You can find them at any store that sells batteries. Hell, in Canada, we even have them at dollar stores like Dollarama.
Without a doubt, the CR2032 is the most common button-cell battery in the world. It's even used in my Veloster's Key-FOB.
Here's a flipkart link, they're in India if I recall correctly:
Eximo
Ambassador
Not a guarantee these days, sometimes they use slightly different button cells for the CMOS battery.
Presumably they are referring to the main battery.
Just a quick google reveals several e-tailers that are likely to ship to India.
battdepot.com, ebay, amazon, aliexpress, possibly newegg. You just need to double check the battery they are selling matches what you have now.
