[SOLVED] Where do i buy a new power supply cable?
CoffeeStoreGuy
281
22
18,815
House burned down in august, and (stupidly) I saved my pc from the fire. When we were running through the rubble we found my power cable, and it works, but I'm afraid to use it, because the prongs are a little yellow and black not misshapen though. I don't know if should get another cable or a new power supply? I also have no clue what my power supply is so if I got a cable I would be guessing.
View: https://imgur.com/a/pWwm0pE
Motherboard: MSI - MPG Z390 Gaming Plus
Cpu: i5 8400 2.8Ghz
GPU: EVGA 1070ti 8gb
RAM: Corsai Vengeance LPX 3000Ghz 16gb
OS: Windows 10 64x
In the US we use 120V as a standard. Just get one that is a similar length and gauge (diameter). If you take it with you to a store they will show you what you need when they see the old cable.
Thanks a lot for the help. I would have no clue without it.
Thanks for the help.
Reactions: Floef
