as the title says i need minimum 3340mm of rgb strip that is 12v and compatible with aura sync, if i can diy it then im up to suggestions if u can describe what i will need to do
Only addressable RGB have to be compatible with SW for control and not even all of them, for ordinary RGB just being 12v is enough. just watch for one thing, 3meters of it can pull quite a lot of power which your controller may not be able to handle.as the title says i need minimum 3340mm of rgb strip that is 12v and compatible with aura sync, if i can diy it then im up to suggestions if u can describe what i will need to do
