Hi, I'm currently using a Corsair H100x with my Asus Prime Z390-P motherboard. On my motherboard I have a slot for the CPU fan and then one for an AIO pump, I was just wondering which slot I should plug the Pump into and the radiator fans into.
The installation guide just says put the AIO pump connector on the CPU fan slot and doesn't really mention the radiator fans. My motherboard guide it says to put the radiator fans on the AIO connection but, with it set up like this my fans go full speed as soon as I start the computer and dont change speed at all after.
Thanks for any help!
