[SOLVED] Where to find good RGB fan controller for Deepcool fans?
Jan 7, 2019
9
My motherboard doesn't have an RBG header, so the fan controller would need to work without one.
My fans are from the brand Deepcool (2x RF120s and 6x RF140s), and I bought the Deepcool FH-10 fan controller but it does not have RGB functionality. I also tried the Coolermaster RGB LED fan controller but the pins on it are slightly different from the pins on my fans (pins on the controller are round-- pins on the fans are square).
So, I'm looking for an RGB fan controller that will work without the RGB header on the motherboard, and that isn't the Coolermaster controller. I would really like to be able to use the RGB on the Deepcool fans I have, so if you have any ideas don't hesitate. Thanks
digitalgriffin
961
203
19,390
20
Ypur fans should have come with a 4 pin jst connector adapter. If you dont have them they are easy enough to find on amazon
https://www.amazon.com/dp/B07B9HK6T3/?coliid=I325HVF4YKV4XR&colid=12HHMQI622ROR&psc=1&ref_=lv_ov_lig_dp_it
These are pricey. At that price i would have demanded at least 5 pair. But with a little patience you can find what you are looking for on amazon or ali express on the cheap.
Jst is more secure but it isnt motherboard/controller friendly as you found out.
digitalgriffin
961
203
19,390
20
Jan 7, 2019
9
Found the cord you described, thanks. I had forgotten about it. Still figuring things out. I'm going to try using the Deepcool fans with the adapter, and the Coolermaster RGB controller.
Jan 7, 2019
9
The Coolermaster controller did not work, but I found the solution. It is severely limited in a way that the Asus Aura software would not be, but it works at a basic level. The fans came with RGB 3-button hardware controllers that I didn't recognize as being controllers, but they do work without an RGB header. And it did require the adapter, so thank you very much.
