Which Cable Do I Need To Connect HD 7770 To TV
Stylo
33
Hey all. I have the Radeon HD 7770 and want to run a cable to my HDMI enabled TV. But I also want to have my monitor connected at the same time.
I notice there are 2 other outputs on the video card. Can anyone help me with the specific cable I need to run this to a TV?
Cheers.
Yes, that is the cable you should use to connect your PC to your HDTV. If you are currently using the HDMI output from your graphics card to your monitor, you should look to see what other ways you have available of connecting the two (DVI, DVI to VGA, DisplayPort, etc...).
-Wolf sends
You mean a cable with HDMI connections on both ends?
-Wolf sends
