Which card is better and will it work with my comp?
anton12350
17
This is my current computer gonna be upgrading soon but this graphics card will probably be for both computers, i was wondering which card is better for me http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=5598652&CatId=7387 or http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2042280&CatId=7387 ?
My current computers specs:
Ram = 4GB DDR3
Graphic Card Support = PCIe
Monitor resolution = 1920x1080
Os = Microsoft Windows 7 Home Premium Edition (build 7600), 64-bit
CPU = AMD Athlon(tm) II X4 635 Processor
Cpu Speed = 2.9 GHz
Power supply = 300w
Of the 2 cards, I would say the Sapphire one as the other one(MSI) has GDDR3 vs GDDR5(Faster!) Unless it is a typo, that is why it cost less.
I dident even notice GDDR3 if thats the case go GDDR5 one
At those settings how would a 7750 cope?
I mean a 7770 will fall well under 30 fps at full settings at 1920 x 1080 so you will need to turn down the settings quite a bit and then video ram does not help.
If you start to push over that screen resolution then yes.
System ram is another beast all together.
Since i do not know of any reviews of the 2gb gddr5 7750's here is something with a bit more power.
http://www.techpowerup.com/reviews/Club_3D/HD_7850_RoyalQueen/1.html
I am not trying be an ass or anything, I just do not think mid level cards with lots of vram are at all worth the cost.
Truly depends. I mean if you don't have the funds to buy your 7850.7950 or 7970 with more then 1 gig of ram surely when you run into a game with more then 1 gig of ram usage you will hit a brick wall. However at the same time you won't be getting higher then high in some areas and medium in most with a 7750.
