A friend of mine recently purchased some 1866Mhz Corsair memory, I guess he didn't check his motherboards specs which only supports 1600 so he is running it under clocked.
I just ordered a Asus Z97-A which should be able to make use of the speed. He offered to swap his memory for the 1600 Mhz G.SKILL with slightly low timings that I intended to put into my build.
So I'm asking which would I be better off with the 1600 9-9-9-24 G.SKILL or the 1866 9-10-9-27 Corsair?
I'll mostly be gaming and I'll also be using an i5-4690k if it matters.
