[SOLVED] Which Power Supply should I get???
Jun 12, 2019
7
I'm from Malaysia and I'm about build a pc, just that I'm not sure which power supply i should choose 🙁 . And like whats the best value and reliability for it. Budget's around RM200-300. I would be willing to spend a bit more tho if it means a much better option.
The rig I'm about to build:
AMD 2600
ASROCK B450M STEEL LEGEND
CORSAIR Vengeance 16GB (2x8) 3000MHZ
GTX 1070
Crucial MX500 240GB SSD
I've narrowed down the list but still don't know which one to get:
View: https://imgur.com/a/4FbN5Fu
