which pump is better? (water cooling)
snon200
357
hi, i want to build a custom loop in my pc, i have this cpu block: swiftech apogee xl , and i have 1 gpu for now (i will add another one in the future), im debating on whether to buy a 850 l/h ddc pump or 1200 l/h d5 pump, which will be better for me and deliver better performance?
90% of the time i run a Swiftech MCP35X pump for my builds. My last build ran a MCP35X with the following setup. 2x 360 RX, 1x 480RX mm rads cpu block and 2x 580 blocks in a single loop and had no water issues. All parts were XSPC except the pump.
I have 1 computer that runs a D5 pump with a Danger den extreme 480mm radiator, EK cpu block and 2 560 ti blocks.
Ether of the Swiftech MCP35X or MCP655 pumps are good have not had issues with ether one of them.
