White screen problem and not boot up..pls help.
windcloud
i got a white screen and computer not booting up. repeating beeping sound..
i try to clear CMOS and boot again..and it works.
but the next day, i boot it up. it doesn't work again..
showing the white screen and that repeating beeping sound..
is there a perm solution to this problem..
i got a amd 2.0 and gigabyte MB.
and pc 2100, 1 pair.
help.
Find out what that beep code means. That is, the mobo is trying tell you what the problem is. These should be in ur mobo manual (or go to the mobo maker's website).
Here's a link to a site with pretty much all the beep codes. You just need to know whther your BIOS are AMI or Award or whatever. If you don't know, just go into the BIOS, the name/type s/b at the top.
<A HREF="http://www.sysopt.com/biosbmc.html" target="_new">http://www.sysopt.com/biosbmc.html</A>
If the beep codes indicate ram, d/l and run Memtest86 a free diagnostic proggie for ram. Download here if needed <A HREF="http://www.memtest86.com/#commands" target="_new">http://www.memtest86.com/#commands</A>
Barton 2500+
Abit NF7-S v 2.0
Maxtor 60GB ATA 133 7200RPM
512MB Corsair Twinx 3200LL
9600 Pro
Enermax Noisetaker 420 watts
Win98SE
