Whiteboard and application sharing do not work
Rick
1,084
Archived from groups: microsoft.public.windowsxp.messenger (More info?)
Help Please!
I am using MSN Messenger V6.2
(Windows Messenger is also installed)
Whiteboard and application sharing, Sound, video and file transfer do
not work (nothing works), I can only Chat (typing) messages.
Looking in Tools/Options/Connection I have the following message:
You are connected to the Internet through a non-UPnP symmetric NAT
(Administrator)
I am connected with a Linksys BEFRS41 router with the following setup
UPnP: Enabled
Firewall & NAT: Enabled
DMZ: Not Enabled
Port Forwarding:
TCP,UDP: 1024-1064,1863,6901
TCP: 1503,1720,1731,522,389,1503,5190,6891-6900
UDP: 6801,2001-2120
UPnP Forwarding:
TCP: 389,5190
Note: I enabled UPnP Forwarding because I ran out of space to enter
ports under Port Forwarding.
I also have a Static IP Address configured IP Address is:
192.168.1.20. Do I need to have a Static IP Address when I have Port
Forwarding Enabled?
I am running Windows XP with SP2
Thanks in advance,
Rick
Correction: In my message I mentioned that:
(Administrator)
But after checking this morning this is what is displayed:
You are connected to the Internet through a UPnP restricted NAT
(Administrator)
I failed to mention that I'm running McAfee Firewall 4.0 but wether the
Firewall is on or off none of the listed features in MSN Messenger works.
"Rick" wrote:
> Help Please!
> (Administrator)
> UPnP: Enabled
> DMZ: Not Enabled
> Port Forwarding:
> UDP: 6801,2001-2120
> UPnP Forwarding:
> TCP: 389,5190
> Forwarding Enabled?
> Thanks in advance,
> Rick
Latest posts
