Question Why does my computer revving then no display on monitor
Jan 28, 2020
5
There may be threads that sound like this but I can predict it. Because it makes a revving sound and then it stops displaying. People show the pc specs so I will too.
Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz 3.00 GHz
Installed RAM 8.00 GB
64 bit OS 64 bit processor
Hi,
What I've noticed in the past, is that it is probably something related to your motherboard not being connected properly to the PSU or your GPU might have a faulty cable somewhere since you are not getting a signal to the monitor.
Check all the cables inside your PC and make sure the are all well connected.
Also, if this is not the case, I'd advise you to provide more detailed explanation of the problem as there isn't much to go from.
