There is no pic to reference the yjtrr speeds you are referring to, but, any CPU has a max turbo speed on a single core, and the base speed it's four, six, or eight (or higher, if you happen to have a 10900K, 3900X, etc.!) cores might run at under an all-core load while maintaining it's TDP, and, a wide variety of clock speeds changing many times per second with each core, depending on load...; HWMonitor will show you what's going on at any particular quarter second or so, with updates several times per second
