Hello all,
I’m new to PC and just built my first PC with the help of some friends a few days ago. I was super excited to finally be using it when I noticed the fans get pretty load and ramp up with me doing much. The PC would be idling and the fans would ebb and flow on ramp up. It would also do this when I’m on a browser just doing some stuff but it gets really loud when I fire up a game like Overwatch. I’m concerned about what’s going on with the processor running at max while idle or doing anything and the fan volume as well.
Here’s my build:
AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor
NZXT Kraken X62 Rev 2 98.17 CFM Liquid Cooler
Asus TUF Gaming X570-Plus ATX AM4 Motherboard
Corsair Vengeance LPX 16gb DDR4-3600 Ram
Samsung 970 Evo 500gb SSD
Asus GeForce RTX 2060 Super 8gb GPU
EVGA Supernova G3 750w 80+ Gold Certified PSU
NZXT H510 Elite with two additional NZXT Aer 2 RGB fans
IDLE
CPU Load: 4% - 7%
CPU Temp: 40-50 degrees Celsius
CPU ClockSpeed: 4000-4200mghz
GPU Load: 0% - 5%
GPU Temp: 40-50 degrees Celsius
GPU ClockSpeed: 300mhz
Ram Load: 20%
Figured I’d list everything on here to help as much as possible. I’ve updated the BIOS to the latest version (I believe it’s v.1005 for Asus TUF X570-Plus), Set things to normal in Bios, and as per what I read set advanced power options to minimum 85% maximum 100%. I’m running NZXT cam software to monitor things but I also have Asus GPU tweak to monitor GPU. As last thing to mention, I’ve been monitor usage in Task Manager and the the most used the PC got is when I’m in Explorer which is not much at all.
Any and all help is greatly appreciated. Like I said I’m new to PCs and would love some help. Thank you in advance.
Here’s my build:
IDLE
CPU Load: 4% - 7%
GPU Load: 0% - 5%
Ram Load: 20%
