[SOLVED] Why is my graphics card usage so low (RX5700XT)
Jul 2, 2020
I recently bought a Rog strix rx5700XT but when i use it on for example battlefield it only uses around 60% usage. I dont have a cpu bottleneck because my cpu is also around 60%. When i try a benchmark like MSI Kombustor it uses 100% and i get a good score, but it never does that in games. How can i fix this?
(btw my temps almost never go higher then 60℃ )
(here are my specs)
gpu Rog strix rx5700XT
motherboard gigabyte aorus b450 elite
cpu ryzen 5 3600 (boosted to 4.2GHz)
Ram Crucial Ballistix Sport LT 2 X 8 GB 3000MHz
power supply Be quiet system power 9 600W
(here are my specs)
There is nothing really to fix, the card will run at higher speeds if it needs to. Increasing resolution and/or quality settings should increase card usage.
(here are my specs)
