[SOLVED] Why is my memory only running at 2133mhz even though they are 3200mhz
djlamp94
BANNED
Nov 11, 2017
65
So I just built my first gaming pc and i've noticed that the memory was only at 2133mhz. I went and turned on the xmp profile for 3200mhz but the pc restarts 2 times and won't allow it to work. My cpu is the ryzen 5 1600. I know that my ram nor the cpu nor the mb is at fault because I built the same pc for a friend at it worked instantly on his pc. For those wondering the xmp profile changed the voltage to 1,35v.
