Question Wifi card touching GPU fan
Sep 15, 2019
There is a piece on my wifi card that is touching the fan housing of my GPU. They are working for now, however I don't like how they have to be spread apart like that. What are my solutions? Can I use a PCIe 1x riser on a ribbon cable and move the wifi card over to one of the openings on the case away from the motherboard? Will there be enough room under the card for the connector to attach?
Pictures: View: https://imgur.com/a/CMcmmeg
Don't see why not, even GPUs can be moved like that.
