Hi - can this be done?
I can get a good wireless WiFi signal. Distance approx. 150 m. I wish to catch it with a device and connect a router to it with an ethernet cable. The device to be mounted outside - router inside apartment. I can fix a box for the device. Temperature never below +3-5C. So grateful if there is a not too expensive solution.
Ciao,
Desperado
Ciao,
Desperado
