[SOLVED] Wifi not working on every iphone in the house but works on all android devices! Help!?
Khant_Kyaw
16
Its been quite along time I've put up with this but my wifi seems to be not working on my iphone or any other iphone in the family but works just fine on all android devices.
I've tried to reset my iphone's network settings but still not working, I've try forgetting and reconnecting the wifi but still no solution.
The wifi connects, it has full bars but no internet at all.
All devices connected with LAN cable works fine of course, just the wireless connection to my iphones.
I would try resetting my router but my ISP made it in a way when i tried to access the " 192.168.1.1 " it will take me to my fiber router(modem) ( which is not capable of wireless connectivity I think )
So I'm afraid i will mess up if i did reset the router because I'm not sure if i can even access the router after the reset.
My Wifi Router is :
TP-LINK TL-WR940N
It works flawlessly on all android devices. Its not the range because I've tried it literally next to the router but still no internet.
I've tried most of the stuffs i saw on google but nothing seems to help. Unfortunately , I dont have an extra wifi router lying around to test if its the router or the iphones
but I'm quite certain its not the iphones since the chances of all the iphones being faulty seems impossible.
But the iphones work on other wifi routers i tested because i have multiple routers with different ISP.
Please help me out, Anything is appreciated.!
So I'm afraid i will mess up if i did reset the router...
My Wifi Router is :
TP-LINK TL-WR940N
Don't go to 192.168.1.1, the main site is 192.168.0.1
Generally 192.168.1.1 is the extened signal
