WILL 250W 6ohms SPEAKER WORK ON A 250W 3ohms CHANNEL AMP
Wayne85
CANT FIND THE 3ohms speaker to go with my system but have found the newer model tht is 6ohms will this replacment work ,
iv been reading around the net and not to sure my self so would like some help please
the system im using is the panasonic SC BT-205 ALL CHANNELS ARE 3Ω
the speaker im replacing is the centre speaker SB-HC300 3Ω 250W
but the only speaker i can find is the SB-HC480 6Ω 250W
Yes, a 6 ohm speaker will work. It won't be as loud as the other 3ohm speakers. That could be a big deficit for the center channel. If you can independently boost the center channel volume, you might be OK. No easy way to predict.
THANKS FOR THE SPEEDY REPLY AND YEAH I CAN BOST OR TURN DOWN ALL THE CHANNELS SEPERATLY
