[SOLVED] Will 450W be more than enough?
ron2456
Will a cx450 (the better white label ones) be enough for my system after I add a Amd Rx570 4/8gb or a Gtx 1060 6gb?
Also I hope there wont be any bottlenecks.
Specs:
AMD Ryzen 2400G
Gigabyte AX370-Gaming 1.x
2x 8gb Crucial DDR4 2400Mhz
1x WD Blue 1tb 1x Samsung 860 Evo 250Gb
Deepcool Gammaxx 300 cpu cooler
5x red led sickleflow x case fans
Corsair CX450
Corsair Spec 01
Specs:
AMD Ryzen 2400G
Corsair CX450
Corsair Spec 01
So long as you don't overclock anything you should be OK at that. Of the two cards, the GTX 1060 is the better option in your case given it uses less power and is a bit faster than the RX570 (you need the RX580 to beat a 1060 but that is more power hungry).
Specs:
AMD Ryzen 2400G
Corsair CX450
Corsair Spec 01
Reactions: ron2456
Latest posts
