Question Will a 2013 model Corsair H60 fit AM4 ?
ryanhill15
i have an old H60 2013 model from a 4690k build but just upgraded to a amd 5800x, was wondering if i can fit it on with one of the AMD mounting brackets ?
Most likely. If you have the AMD mounting kit that looks like this:
https://www.amazon.com/Cooler-Bracket-ForCORSAIR-Hydro-H100i/dp/B083FTCBGQ
It should work, or you can buy that.
That is well beyond the expected service life of a AIO, if it has been in use for more than 5 or 6 years, you might want to consider a replacement. Not to mention that many large air coolers outperform a single 120mm radiator.
