will a asus motherboard work with a amd chip as long as sockets is compatible
pcloverakagameboss
70
will amd fx-6350 cpu work with asus m5a78L-m lx motherboard or asus m4n68t-m motherboard and also will same socket cpu and motherboards work together .
Barty1884
Retired Moderator
ASUS make boards for both AMD and nVidia chips - so provided the socket it compatible and the appropriate BIOS revision is installed, along with appropriate support for the TDP of the chip - you'll be fine.
https://www.asus.com/us/Motherboards/M5A78LM_LX/HelpDesk_CPU/
The 6350 is not a supported chip on that motherboard though. Max chip TDP is 95W and the 6350 is a 125W CPU.
CTurbo
Pizza Monster
MERGED QUESTION
Question from pcloverakagameboss : "will amd fx 6350 work on a M5A78L- M plus"
It will "work" but it is not going to be able to run at full speed. It will throttle under loads and overall performance would be terrible. The motherboard just simply cannot handle a 125w cpu.
MERGED QUESTION
Question from pcloverakagameboss : "cheapest motherboard for amd fx 6350"
That's an older hard drive. It will work 100%, but you might want to give it a health check - programs such as crystal disk info will help you there: http://crystalmark.info/software/CrystalDiskInfo/index-e.html
And the fx does better in synthetic benchmarks but loses to the g4560 in most games: https://www.youtube.com/watch?v=yRWsoWWtXA8
