[SOLVED] Will a gtx 1660 ventus fit?
Jan 2, 2021
I have a question, i would like to buy a gtx 1660 ventus but i do not know if it will fit and work properly on my motherboard Ga-78lmt-s2p, please help
So long as your motherboard has an available PCIe x16 slot, you can drop the intended GPU into it. I am concerned about the make and model of your PSU and it's age and if your cases' airflow is good, considering that something as old as your platform(assuming from the make and model of the motherboard), might be bad.
