Question Will a Mini ITX MOBO fit in the Corsair Carbide SPEC-M2?
Penrose
Commendable
May 26, 2019
89
I'm looking to get a Mini-ITX motherboard: MSI B360I Gaming Pro AC Motherboard
And my case that I currently have the the Corsair Carbide SPEC-M2. It is a mATX case, but in the specs it only says mATX, so I'm wondering if I can put an ITX motherboard in it.
It will probably fit, but not all of the holes will line up.
I have a b85m-e micro motherboard, used it in 440 NZXT case, only 4 holes lines up with 4 of the motherboard standoffs.
Advice, if only 5 or something lines up, and there is still a standoff under the motherboard that is not lining up remove it so it doesn't short out your motherboard.
Just checked the website, says in compatibility: Mini ITX and mATX.
