Will a r7 250 work in a pci e 1.0 x16 slot
jack turnbull
18
okay so i was wondering if i could put a r7 250 in a x16 pci e 1.0 slot and if it would work would there be any fps droping with it being in a older pci slot
well what gpu would run with here are my specs if it help cause i will upgrade it in the future
Intel i3 3240t @2.9ghz
4gb ram
1tb hd
it just needs to run borderlands the pre sequel ant low to med
No a PCIe3.0 should work in that slot however, it will only be able to run at 250GB transfer speed on that one lane. The PCIe3.0 card you have will have to throttle way down since it is designed to run at PCIe3.0 speeds.
Correct. Some people have said that it will and some say that it bottlenecks so bad that it doesnt work. Thats why I say it wont because I dont want to tell people it will work no problem than all of sudden nothing works.
