R Ryathor Distinguished May 1, 2014 50 0 18,530 Sep 1, 2016 #1 I bought the Thor v2 case by Rosewill. I was just wondering if I should go with the Bigger H115i cooler, which is a 280mm radiator, or the smaller H100i which would be 240mm. Thanks.
Solution Dark Lord of Tech Sep 1, 2016 Not compatible according to pcpartpicker. It's a little too big , I've come across this question before. https://pcpartpicker.com/products/cpu-cooler/#m=11 Are compatible.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,747 1,832 159,590 Sep 1, 2016 Solution #2 Not compatible according to pcpartpicker. It's a little too big , I've come across this question before. https://pcpartpicker.com/products/cpu-cooler/#m=11 Are compatible. Upvote 1 Downvote Solution
Tbonius Distinguished Aug 3, 2007 185 10 18,715 Sep 1, 2016 #3 I have a Thor V2 with an H100i and it just fits, I can't see any way you could get a bigger radiator in it. Upvote 1 Downvote
