Will a tx650 watt psu work for this card?
D
Deleted member 362816
Guest
worked for a amd 965----gtx 460 2win build will it work for fx-8350 gtx 4602win the card used like 450+ watt at full load according to some sites.
Need to know this asap or I will have to order a new psu
also figure all your drives in to this too. dvd, hdd, ssd, usb devices, fans, anything that draws power from the psu needs to be figured in also. I figure you Have a max of 60W (because you cant count on your PSU to put out a full 650w) to play with for the items I mentioned above. I say its too close.
edit: Example i have 8 fans in my case and if they all draw 3W that's 24W just for fans dvd will draw 5-10 watts. my ssd draws 3W and hdd draws say 5W (because i cant fined exact wattage for it) now using the lowest numbers that is 37W leaving 23W left. I would not do it but my system is different for power usage.
I'm not comparing it to a GTX 460, I'm comparing it to TWO GTX 460s.
