Will an i7-7700k work with a RAM that's speed is 3200MHz?
marci.petes
Commendable
Nov 17, 2018
11
I've seen this question with different CPU versions and RAM speeds but I wasn't sure. I created my PC build containing the following CPU and RAM:
CPU: i7-7700k
RAM: HyperX 16GB Fury Black DDR4 3200MHz CL18 HX432C18FB/16
I do not know if they will work together to their full extent.
Thanks for the help in advance. ^^
- T
I never knew MOBO's had a speed limit as well. It's an ASUS PRIME B250-PLUS. I checked intel's site and it said that this:
Memory Types: DDR4-2133/2400
This is why I asked the question in the first place. It should work with 3000 MHz though at least that's what I found by searching the site.
-T
Actually the 3200 MHz I picked was cheaper then the original 2400 MHz. The only change I could find in 16 GB Rams were a few dollars but that isn't much.
Thanks for the answer
-T
