9 902 Honorable Jan 9, 2013 285 0 10,790 Feb 27, 2013 #1 The title pretty much says it if i overclock my gpu will it stay at full power even if i'm just web browsing?
Solution COLGeek Feb 27, 2013 No problem. Your GPU will only spike up only under load (like when gaming). Have fun! You can ask a mod to close for you.
COLGeek Cybernaut Moderator Apr 6, 2009 54,480 3,501 179,340 Feb 27, 2013 #2 No, it should not. Upvote 0 Downvote
9 902 Honorable Jan 9, 2013 285 0 10,790 Feb 27, 2013 #3 Thanks for the quick answer i forgot to put it as a question thread, sorry. Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 54,480 3,501 179,340 Feb 27, 2013 Solution #4 No problem. Your GPU will only spike up only under load (like when gaming). Have fun! You can ask a mod to close for you. Upvote 0 Downvote Solution
9 902 Honorable Jan 9, 2013 285 0 10,790 Feb 27, 2013 #5 Close please and can you change to a question thread so i can select best answer, thanks! Upvote 0 Downvote
9 902 Honorable Jan 9, 2013 285 0 10,790 Feb 27, 2013 #6 Best answer selected by 902. Upvote 0 Downvote
