Will DVI-D(single link) to VGA cable work on GTX1050TI?
fmpsagara
32
I have a Palit GTX1050TI and unfortunately, I have a monitor with only VGA port.
So originally, I was thinking of buying a DVI-D to VGA adapter but while searching I found out that it won't work if it's a passive adapter. Since I think it's hard to find an active adapter here in my area, I did some research again and stumbled on a DVI-D(single link) to VGA cable. My question is, will it work on my setup? Or will it be just the same as using passive adapter?
the problem is that the 1050ti only gives a digital signal. the vga is an analog one. the "active" adapter changes the signal to an analog one that the monitor can use.
so a single link adapter is just as useless as a dual link one if it is passive. you need an active adapter to use the card with the vga monitor, no way around it.
How about a DVI-D single link to VGA cable? Will it work? It's not an adapter, it's a cable with DVI-D on one end and VGA on the other end. Like this: Link
No. As we have said only an active adapter/converter will work.
right the cable is simply the adapter with a cable in the middle. still "passive" and not going to convert the digital signal to an analog one like you need.
where are you looking to shop for this? a couple online store links and we should be able to locate one if it is available. would save a ton of back n forth that will in the end go nowhere.
Noted. Thanks guys!
I'm trying to find one on local stores. I never knew there was active and passive until I did some research. Could have wasted money on useless cables/adapters -_-
How about HDMI to VGA adapter or cable? Will that work? or still no?
so long as it is an active one then an hdmi to vga would also be fine. they even have display port to vga but they are harder to find.
most of the time an active one plugs into the wall for power. these models tend to perform better than ones that don't plug in.
but if you can only find one locally, then you got to go with what you can find
Is there like a way on how to determine an active from passive? Saw someone selling HDMI to VGA but I can't distinguish if it's active or not. Here are some pics: Picture1Picture2
is there a model number you can see on it? i'd do a quick google search at the store to be sure exactly what it is.
it will be obvious though if it is or not once you hook it up. if it is not active then you'll get a blank screen, so a pretty simple field test to know for sure
I still have to ask from the seller. I'll get back to you once I get some information.
Can you tell if this one's an active or not? DVI-D to VGA adapter
Thanks! I think I'll have to go for HDMI to VGA. I'm really having a hard time looking for DVI-D to VGA here.
