[SOLVED] Will GTX 960 work with a VGA monitor connected by a passive VGA - DVI-I adapter?
Nov 26, 2020
9
Hi, I have a VGA only monitor and I am wondering if i can use it to connect a GTX 960 by a passive VGA to DVI-I adapter. Does GTX 960 support analog signals?
DVI-I has analogue pins and would work with a VGA monitor but need to figure out what type of DVI port the card has. Check the graphics card spec sheet/manual.
What specific 960 brand/model do you have?
If card only has DVI-D port, there are active adapters to VGA available.
