[SOLVED] Will i be able to use a CRYORIG H7?
Agustin_2
13
Hey! thanks a bunch for checking this out. i was wondering if the CRYORIG H7 would be compatible with my stuff, i have team t force delta rgb ram, my case is a cooler master masterbox q300p, i have a ryzen 5 3600 currently using stock cooler, my mobo is an asus prime b450ma csm and i have a sapphire pulse rx 5700xt which is quite tick. thanks a bunch for reading, this is the fan.
https://www.newegg.com/cryorig-h7-quad-lumi/p/13C-000U-00019?Item=9SIA85V66M4911
CLEARANCE - CPU COOLER159mm
Dimension ( with fan )
L98 mm x W123 mm x H145 mm
http://www.cryorig.com/h7ql.php
Even if the cooler had some compatibility issues with your RAM (which it shouldn't), you have 14mm clearance to raise the fan.
No issues that I can see.
Thanks a bunch! don't really know a lot about this stuff so i was a tad insecure. have a nice day c:
